0.98.1: Animation image size is incorrect
Mapaler
Post by Mapaler »
XnView: MP 0.98.1 - 64 bit
OS: Windows 10 64bit
I previously posted it in the suggested section: ./viewtopic.php?f=60&t=40214
This is the original GIF file.
But Image Size in XnViewMP it's not correct. :bug:
Expected behaviour: This is the correct image size in Fireworks
Includes GIF, WebP, may only calculate the first frame size. You can download the webp at ./viewtopic.php?f=101&t=40157.
I haven't found the problem with APNG for the time being. Perhaps because APNG is not in the official png standard, the full size is recorded directly.
I also hope you can consider this suggestion
./viewtopic.php?f=60&t=41338
Fixed in 0.98.1
Can't stop animation
When you click on the next page, the animation don't stop. Includes GIF, APNG , WebP.
Actual behaviour (bug): The animation still plays. :bug:
Expected behaviour: The animation stops and the frame is displayed.
Crashed on open the Batch convert when view an animation
When you view an animation, click Menu - tools - Batch convert.
Actual behaviour (bug): The program crashes. :bug:
Re: 0.98.1: Animation image size is incorrect
ok i'll check
