0.98.2: Filter is retained by mistake
Mapaler
Post by Mapaler »
XnView: MP 0.98.2 - 64-bit
OS: Windows 10 - 64-bit
Effect: The filter is incorrectly retained in the picture result and is not undone.
  • Open a picture and select the Filter
  • Checked the Apply to image
  • Select a Filter that can see the changes
  • Then click several times Undo
  • The filter is loaded on the image :bug:
  • Click Cancel
  • The picture will retain all the Filter change :bug:
    And switching with the front or back pictures is still preserved
    However, the real file has not been modified
