0.98.1: Film Simulation remove Alpha channel
Mapaler
Post by Mapaler »
XnView: MP 0.98.1 - 64-bit
OS: Windows 10 - 64-bit
Effect: The Alpha channel is removed.
  • Open a picture and select the Film Simulation
  • Choose any style
  • Alpha channel is removed
Re: 0.98.1: Film Simulation remove Alpha channel
yes film simulation can't work with alpha channel
Mapaler
Post by Mapaler »
xnview wrote: Sun Jan 24, 2021 1:56 pm yes film simulation can't work with alpha channel
You can add steps to get the effect
  1. Extract the Alpha channel
  2. Apply film simulation
  3. Merge the Alpha channel back
