How can I do this? I can make a 2X2 collage easily with Create>Join Images. But I have to select the pictures I want to do.
I want to make a collage by selecting 4 folders, and each thumbnail would be the first picture in each folder.
Maybe you know a better way entirely though. Thanks.
Want to create a collage using the first picture in every folder.
fredsp
Re: Want to create a collage using the first picture in every folder.
a workaround is to show files with subfolders and select them
