b1: problem with EXIF user comment in slideshow
Locked
Dirk
Post by Dirk »
an old bug is back again:
http://newsgroup.xnview.com/viewtopic.p ... highlight=
maybe it's the same problem with the bad EXIF-format of CanonA80?
@Pierre: you have saved my last sample picture? :-)
Re: beta 1 bug: problem with EXIF user comment in slideshow
Dirk wrote:an old bug is back again:
Ok, i check
Dirk wrote:@Pierre: you have saved my last sample picture? :-)
Please, sorry could you send me again your picture, i don't find it :-(
Dirk
test picture
Post by Dirk »
I sent you a test picture (canonA80_test_picture.JPG) again.
And don't loose it again.... :D :D :D
Dirk
Closed
Post by Dirk »
Fixed in B2 :bugfixed:
Locked
