Hi all
About "Settings, Catalog" window :
We can (or not) select some folders in the table.
Can anyone explain the effect of the different actions below ?
1) Check folders button
What's it's job ? Does it apply to the selected folder , or all folders ? (all folders beginning at C:\ ? or all folders already here in the table ?)
2) Rebuild Thumbnails Button
Does it rebuild thumbnails inside the selected folder ? inside all folders ? rebuild also "Folder's thumbnails" ?
3) "Optimze" button
3a) Does "optimze database" always optimize the whole DB ? which job is done ?
3b) Remove data for empty directories : on whole DB or only selected folder ?
3c) Purge all thumbnails : is it the same as deleting Thumbs.db ?
3d) Purge file data : what is this action ?
3e) Remove data from orphaned directories : what are orphaned directories ? is it the same action as 3b ?
... orphaned directories are directories deleted with another software
3f) Remove data from orphaned files : what are orphaned files ?
... orphaned files are files that were deleted out of xnviewmp
For all these questions : what about star ratings ? color labels ? people ? Tags ? Is there a risk that they will be deleted from DB ?
My own answers :
For 3e) and 3f) : In French, "orphaned" is translated as non-existent. This is much more understandable.
It means that files or folders deleted (out of XnViewMP) must be removed from DB.
Other buttons:
- "Add Folder" button makes XnViewMP read metadata and add information in it's DB (=catalog) , only if "import" option is enabled in settings, metadata.
- "Delete" removes selected folders from the catalog.
- "Relocate" is used when folders have been moved or renamed out of XnViewMP, so it will be able to rebuild links with moved files, in it's DB.
* If one sends me some answers by PM ( private message or MP in french as well) , I can edit this first post and add answers with colours , so it will be easier to read in the future ... Thanks
Settings Catalog options
Catalogage avec XnviewMP :
Re: Settings Catalog options
All folders in catalog will be checked for new filesmichel038 wrote: Fri Feb 05, 2021 2:00 pm 1) Check folders button
Rebuild thumbnails for files/folders in selected folder list2) Rebuild Thumbnails Button
Yes whole DB, check all items in catalog3) "Optimze" button
whole DB3b) Remove data for empty directories : on whole DB or only selected folder ?
yes3c) Purge all thumbnails : is it the same as deleting Thumbs.db ?
Remove file entry3d) Purge file data : what is this action ?
folders that don't exist anymore3e) Remove data from orphaned directories : what are orphaned directories ? is it the same action as 3b ?
files that don't exist anymore3f) Remove data from orphaned files : what are orphaned files ?
Thank you, I'll update my tutorial with these informations.
