How to display only images with specific rating in full screen view mode?
I like to view images in full screen mode. Is there a way how to display only images with specific ratings in full screen view mode? Oh, I use XnView MP. Thank you!
Re: How to display only images with specific rating in full screen view mode?
Open "Categories Filter" pane, and select the star level you want. Thumbnails are displayed.
- Double click on the first one, it opens in "view mode" (= full screen into XnViewMp window) , use toolbar's buttons to navigate.
OR
- Select them all (Ctrl A) and click on slideshow button (or Create, Slideshow menu)
OR
- Select the first one, use F11 key (or View, Full Screen menu)
here, when moving mouse to the right side, you can see detailed info, and to the top, a ribbon is displayed ...
OR
OR
Catalogage avec XnviewMP :
Thank you. I have one more question. When I open "Categories Filter" pane and I select the star level, I see all images with this rating. Thats cool, but sometimes I want to see only images in specific folder. Is this possible?
Never mind. I figured it out
There is option for this in category filter panel
Oh, I have a last question. Is there a way how to filter images by specific metada? For example show only images with GPS location? Thank you.
Some metadata can be used in "Search" function (Binoculars, or Ctrl F)
But "Exif, all fields" does not give the results I was waiting for (I tried WGS-84 for GPS data ... doesn't work)
I tuned my overlay icons to get a red GPS icon in my browser ...
viewtopic.php?f=60&t=41206
mibro - you said you had worked out how to view images with a specific rating in a folder of images. Can you tell me your solution as I need to do the same. Thanks.mibro wrote: Sun Feb 07, 2021 6:44 pm Thank you. I have one more question. When I open "Categories Filter" pane and I select the star level, I see all images with this rating. Thats cool, but sometimes I want to see only images in specific folder. Is this possible?
