Dark Images in XnViewMP
grcolts
Post by grcolts »
Ok, I downloaded XnViewMP for Mac and in general find it to be very fast and stable so far. One bug? or problem is that when I import jpegs from darktable most come out fine but others come out really dark. Anyone else experience this problem? I can copy a dark image to another folder or desktop and the image is fine. Perplexed? Anyone know what is going on with that scenario?
Thanks
GQR
Re: Dark Images in XnViewMP
could you post a file?
grcolts
Post by grcolts »
xnview wrote: Wed Feb 10, 2021 8:23 am could you post a file?
The lighter image is what it is supposed to look like, the darker image is how it appears in XnViewMP.
GR
i means the original file
grcolts
Post by grcolts »
File
Filepath /Users/grcolts/Desktop/DT-SPI Boat Tour 2:6:2021
File size 2.30 MiB (2,411,045)
Creation date/time 2/9/21 - 9:14:34 AM CST
Modified date/time 2/9/21 - 9:14:34 AM CST
Accessed date/time 2/11/21 - 10:48:38 AM CST
Rating 0
Colour Label 0
Format JPEG TrueColor (v1.1)
Width 1137
Height 1521
Dimension 1.7 Mpixels
# of bits 24
Color model RGB
DPI 300 x 300
Print size 9.63x12.88 cm, 3.79x5.07 inches
Compression JPEG
Progressive mode No
Sub-sampling 1x1,1x1,1x1
Estimated quality 100
Images/frames count 1
Origin Top-Left
Color Profile
Description Linear Rec709 RGB
Manufacturer darktable
Model Linear Rec709 RGB
Copyright Public Domain
I think Pierre may need the original image, best to put both normal and dark JPEGs in a ZIP and attach it, if that is possible...
I downloaded both of the posted thumbnails when they were first posted, and couldn't see any difference in the properties, although I might have missed something.
grcolts
Post by grcolts »
I figured out what was happening as far as the dark images showing up in Xnview MP.
When exporting from darktable, the output I noticed the output was set to Linear Rec709 RGB; so, I changed the setting output to Srgb.
Everything worked as it should. Images processed in darktable now appear as they perfectly in Xnview MP.
Yippee!
GQR
