XnView MP doesn't run on Xubuntu 20.04 LTS 64 bit
blablaalb
Post by blablaalb »
Hello everyone. I installed XnView MP on my Xubuntu machine, but it doesn't start. Here's the output from the console:
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, webgl, xcb.
Aborted (core dumped)
Re: XnView MP doesn't run on Xubuntu 20.04 LTS 64 bit
try to start it from command line
blablaalb
Post by blablaalb »
That's how I got the output. I entered xnview into the console and the output came out
blablaalb
Post by blablaalb »
I set QT_DEBUG_PLUGINS to 1 and this is the output I get when I try i run xnview
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/lib/platforms" ...
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqlinuxfb.so"
Found metadata in lib /opt/XnView/lib/platforms/libqlinuxfb.so, metadata=
    "IID": "org.qt-project.Qt.QPA.QPlatformIntegrationFactoryInterface.5.3",
    "MetaData": {
        "Keys": [
            "linuxfb"
    "archreq": 0,
    "className": "QLinuxFbIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("linuxfb")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqminimal.so"
Found metadata in lib /opt/XnView/lib/platforms/libqminimal.so, metadata=
    "MetaData": {
        "Keys": [
            "minimal"
    "archreq": 0,
    "className": "QMinimalIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("minimal")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqminimalegl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqminimalegl.so, metadata=
    "MetaData": {
        "Keys": [
            "minimalegl"
    "archreq": 0,
    "className": "QMinimalEglIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("minimalegl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqoffscreen.so"
Found metadata in lib /opt/XnView/lib/platforms/libqoffscreen.so, metadata=
    "MetaData": {
        "Keys": [
            "offscreen"
    "archreq": 0,
    "className": "QOffscreenIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("offscreen")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqvnc.so"
Found metadata in lib /opt/XnView/lib/platforms/libqvnc.so, metadata=
    "MetaData": {
        "Keys": [
            "vnc"
    "archreq": 0,
    "className": "QVncIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("vnc")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-egl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-egl.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-egl"
    "archreq": 0,
    "className": "QWaylandEglPlatformIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("wayland-egl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-generic.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-generic.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland"
    "archreq": 0,
    "className": "QWaylandIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("wayland")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-xcomposite-egl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-xcomposite-egl.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-xcomposite-egl"
    "archreq": 0,
    "className": "QWaylandXCompositeEglPlatformIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("wayland-xcomposite-egl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwayland-xcomposite-glx.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwayland-xcomposite-glx.so, metadata=
    "MetaData": {
        "Keys": [
            "wayland-xcomposite-glx"
    "archreq": 0,
    "className": "QWaylandXCompositeGlxPlatformIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("wayland-xcomposite-glx")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqwebgl.so"
Found metadata in lib /opt/XnView/lib/platforms/libqwebgl.so, metadata=
    "MetaData": {
        "Keys": [
            "webgl"
    "archreq": 0,
    "className": "QWebGLIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("webgl")
QFactoryLoader::QFactoryLoader() looking at "/opt/XnView/lib/platforms/libqxcb.so"
Found metadata in lib /opt/XnView/lib/platforms/libqxcb.so, metadata=
    "MetaData": {
        "Keys": [
            "xcb"
    "archreq": 0,
    "className": "QXcbIntegrationPlugin",
    "debug": false,
    "version": 331520
Got keys from plugin meta data ("xcb")
QFactoryLoader::QFactoryLoader() checking directory path "/opt/XnView/platforms" ...
Cannot load library /opt/XnView/lib/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory)
QLibraryPrivate::loadPlugin failed on "/opt/XnView/lib/platforms/libqxcb.so" : "Cannot load library /opt/XnView/lib/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory)"
blablaalb
Post by blablaalb »
ldd /opt/XnView/lib/platforms/libqxcb.so  | grep "not found"
gives the following result:
	libxcb-icccm.so.4 => not found
	libxcb-image.so.0 => not found
	libxcb-keysyms.so.1 => not found
	libxcb-render-util.so.0 => not found
	libxcb-xkb.so.1 => not found
	libxkbcommon-x11.so.0 => not found
	libicui18n.so.56 => not found
	libicuuc.so.56 => not found
	libicudata.so.56 => not found
blablaalb
Post by blablaalb »
So, I installed the missing packages and now I'm able to run the XnView. Hooray :D !
sudo apt install libxcb-image0
sudo apt install libxcb-keysyms1
sudo apt install libxcb-render-util0
sudo apt install libxcb-xkb1
sudo apt install libxkbcommon-x11-0
great :)
bwmarrin
Post by bwmarrin »
blablaalb wrote: Wed Feb 10, 2021 10:54 am So, I installed the missing packages and now I'm able to run the XnView. Hooray :D !
I ran into this problem as well and your debugging helped. I installed the packages you listed but I also needed to install libxcb-icccm4 to get it working on Debian 11 / XFCE4. Just sharing here in case someone else stumbles onto this post looking for a fix :)
