Configure Programs - Multiple files don't work when giving the filename as parameter
stevehero
Post by stevehero »
I'm using this for ShareX.exe to open in their editor:
-ImageEditor %1
Along with ShareX.exe in the path.
The above works with one file but not when trying with more than that.
Seems that instead of doing this:
ShareX.exe -ImageEditor %1
ShareX.exe -ImageEditor %2
ShareX.exe -ImageEditor %3
etc.
It's doing this:
ShareX.exe -ImageEditor %1 %2 %3
Re: Configure Programs - Multiple files don't work when giving the filename as parameter
Post by michel038 »
maybe you can call a .bat file containing a loop
something like
:bb
if z%1==z go to end
shift
goto bb
:end
You can also add a button in a toolbar, with the same method.
stevehero
Post by stevehero »
michel038 wrote: Fri Feb 12, 2021 11:22 pm maybe you can call a .bat file containing a loop
Thanks, that's doing an endless loop.
There was a typo or 3 ;)
I've modified it to work.
Any way to get an icon, fairly new to XnV. I've checked the .ini file but not sure how to do that.
:bb
if %1==z goto end
"W:\Apps (Portable)\Screen Capture Apps\ShareX\ShareX.exe" -ImageEditor %1
shift
goto bb
:end
exit /b
It does seem as though this is a bug. Hopefully, the devs can see this.
The batch file seems to be needing to be hardcoded into the path so it would be good to get the built-in method to work.
