0.98: When app is open - Clicking on same file doesn't bring XnView MP to front of others
stevehero
Post by stevehero »
XnView: MP 0.98 - 64 bit
OS: Windows 64bit
Effect: Undesired behaviour.
1. Click on an image on the desktop for example, XnView will open the file.
2. Switch to chrome or any other app.
3. Having the other app still visible, click on the same image on the desktop.
4. XnView will not be brought to the front.
Expected behaviour: Clicking on the file in step 3 should bring XnView to the front of any others.
Re: 0.98: When app is open - Clicking on same file doesn't bring XnView MP to front of others
so with 'only one instance' setting?
stevehero
Post by stevehero »
Yes, Allow only one instance of XnView.
stevehero wrote: Tue Feb 16, 2021 3:06 pm Yes, Allow only one instance of XnView.
Windows doesn't allow to an app to go in foreground
stevehero
Post by stevehero »
xnview wrote: Wed Mar 03, 2021 4:16 pm
Other programs such as Photoshop, AutoCAD, Sublime Text all work in this way as I've described as the expected behaviour.
EverGreen
Post by EverGreen »
Im sorry Pierre but you're wrong.
Windows allow app to go in foreground. Your's previous version of XnView (NOT MP VERSION) works as expected.
Right, See issue for current status and some details.
EverGreen
Post by EverGreen »
xnview wrote: Tue Mar 09, 2021 11:36 am Right, See issue for current status and some details.
I follow your software for at least 10 years.
If i not wrong i discovered this amazing software on a Windows XP Colossus edition (Disc 2). From this, i never change to another image viewer.
I waiting for next release to check.
Thanks Pierre. You are the best.
stevehero
Post by stevehero »
Thanks for fixing this. Looking forward to the release.
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
stevehero
Post by stevehero »
I've updated and the issue is still there.
BuildNumber  Caption
19042        Microsoft Windows 10 Pro
XnView MP Windows
Version 0.98.3 64bits (May 6 2021)
yes strange, works sometimes. But i have the same behaviour on XnView Classic
EverGreen
Post by EverGreen »
stevehero wrote: Fri May 07, 2021 9:11 pm I've updated and the issue is still there.
BuildNumber  Caption
XnView MP Windows
I updated and yes, bug persist. I notice the bug is related with xnview.exe minimized or not.
How to reproduce with bug:
1. Open random image
2. select folder with images again and open another.
How to reproduce without bug:
2. Minimize XnViewMP.exe (This is important)
3. Open another image and voilá, XnViewMP.exe brings to front!!!
Pierre, you're really close to solve. I hope on next build you solve this!!!
stevehero
Post by stevehero »
As EverGreen has said, I'm getting the same behaviour.
ok, a workaround is to minimize the app, Issue reopened
