Maybe some improvements
terasek
Post by terasek »
Hi !
I'm working a lot with XNViewMP to optimize my photos.
While working for hours I found some things that might enrich the workflow.
1. Remember the last filter used and start with that filter again.
2. Remember the filter settings (I noticed the Unsharp Mask settings are reset all the time, I think it's the same for all the other filters...)
3. Make it possible to set the tabs below the toolbars (maybe as a alternative to bottom and top)
Just ideas, what do you think ?
Regards,
Maik
electro1
Re: Maybe some improvements
Post by electro1 »
#3 is definitely more logical than the current layout with the tabs above the menu. There should be an option to select the preferred version.
terasek wrote: Sat Feb 13, 2021 5:14 pm 1. Remember the last filter used and start with that filter again.
Right, setting for filter are not kept, and filter is not kept (can be slow)
Sorry but currently it' s not possible, the menu bar is different following content 's tab
