1. Correct russian translation:
There should be "Восстановить расположение E"
https://i.imgur.com/T6X4eAq.png
2. Make layout follow percentage offset or somehow another way. I'm very annoyed by the situation dat changing window size fully breaks layout. I should restore layout preset every shitty time. The layout should be relative to full window size. It's absolute as I understand so resize breaks it.
Video demo: https://gfycat.com/MemorableVelvetyIcelandicsheepdog
Translation mistake + Layout repositioning
Re: Translation mistake + Layout repositioning
Okfalcon wrote: Wed Feb 17, 2021 3:19 am 1. Correct russian translation:
Ok, i'll check if it's possible2. Make layout follow percentage offset or somehow another way. I'm very annoyed by the situation dat changing window size fully breaks layout. I should restore layout preset every shitty time. The layout should be relative to full window size. It's absolute as I understand so resize breaks it.
