Save As Photo then open Saved as Photo
zzapper
Post by zzapper »
I feel I'm probably overlooking something simple :?
I open photo IMG_20210211555.jpg and do some cropping etc then SAVE AS funny-cat.jpg
I now would like funny-cat.jpg to be automatically the image open in XnViewMP so I can carry working on it.
I know I could do this with rename but that's not what I want either
Any tips?
Re: Save As Photo then open Saved as Photo
settings>General>File operations - use output filename after save as?
zzapper
Post by zzapper »
Pierre
That was already set. Curiously sometimes I do save as and then find that the open image is the one I've just saved.
### it works if you save as to same directory but not if you save as to a different directory ####
yes right, but there is a problem. If you change the file folder, the viewer should go to this folder too?
zzapper
Post by zzapper »
Pierre
No I wouldn't want to move to the saved folder, drat!!
