Error opening folder from cmd line [can be deleted]
MARK2580
Post by MARK2580 »
Found an error that XnVIewMP refuses to open the hidden folder from the cmd line i.e. xnviewmp.exe <folder>. A message appears that "file not found". Show hidden files is enabled in XnVIewMP settings. :bugconfirmed:
Re: Error opening folder from cmd line
if the folder is not hidden, no problem?
MARK2580
Post by MARK2580 »
xnview wrote: Sat Feb 27, 2021 10:12 am if the folder is not hidden, no problem?
Cancel ! This error does not exist !
This is my personal oversight. The problem was in a folder with a space in its name. The path was transmitted from Total Commander without quotation marks. I had to use ""%P"" and it worked.
