bookmark.ini-Setup for "C:\Users\[USERS]\Pictures" etc.
Gerald_Ire
Post by Gerald_Ire »
Using xnviewmp Version 0.98.1 64bits (Jan 20 2021)
Setups over AppData\Roaming\XnViewMp\... for alle users
Files: xnview.ini + default.bar + bookmark.ini
So far so good (thx to this all!)
Like to setup a standard bookmark.ini for 1st. setup for all users to standard user folders:
C:\Users\[USERS]\Donwloads
....without changing GPO or any other Windows-Setups.
A hint? :?
:D Gerald says thx to all! :D
Re: bookmark.ini-Setup for "C:\Users\[USERS]\Pictures" etc.
No sorry, you need to copy these files for all users
Gerald_Ire
Merci!
So I add this in the handout for all users to bookmark there User folder themselfs.
Keep fingers crossed and thumbs up!
