If I search for pictures by category (on the left), every found image is shown twice.
Search by categories list shows every image twice
hic
Re: Search by categories list shows every image twice
do you use 'base path'?
hic
In catalogue settings? Yes, it is set to "Pictures".
you use multiple computer to access the catalog?
hic
No, alway the same computer.
so why do you use 'base path'?
It seems that you have in the catalog some files with 'base path' activated and some without
