PNG with Alpha Channel is broken wiev
Re: PNG with Alpha Channel is broken wiev
'Use alpha channel' is enabled?
Mrakobes666
it seems that View>Use alpha channel is not enabled
CleverPig
Sorry for writing here, I do not know what is Alpha Channel, but I have a problem a certain png files too. Some were broken(half downloaded), but another seems perfectly fine(and MS Paint opens all these files). XnView just refuse to open such files and shows empty gray screen with error(with default settings).
So the solution is: Options>Formats>Read - check "ignore read errors"
Hope this will help someone eventually too
could you send me a sample file?CleverPig wrote: Fri Mar 12, 2021 11:48 am Sorry for writing here, I do not know what is Alpha Channel, but I have a problem a certain png files too. Some were broken(half downloaded), but another seems perfectly fine(and MS Paint opens all these files). XnView just refuse to open such files and shows empty gray screen with error(with default settings).
Hope this will help someone eventually too![]()
Mrakobes666
Mrakobes666
Finally found it! Not in browser mode! Everything works, but the settings are not saved - each new file has to be re-enabled. How to set the default?
Rick
Settings / Browser / thumbnail / Use Alpha channel?
Rick
Rick
Mrakobes666
Yes, but it doesn't affect the display in full screen. I don't know who needs to see a png without an alpha channel by default. How do I enable it permanently?
By default it's on, in browser preview you have no alpha used?Mrakobes666 wrote: Fri Mar 12, 2021 4:48 pm Yes, but it doesn't affect the display in full screen. I don't know who needs to see a png without an alpha channel by default. How do I enable it permanently?
Mrakobes666
No, it has never been turned on and when I turn it on, it rolls back every time
Do you talk about settings in preview of browser or edit mode?Mrakobes666 wrote: Thu Mar 18, 2021 6:20 pm No, it has never been turned on and when I turn it on, it rolls back every time
Mrakobes666
I did a lot of manipulations as an experiment, then it is displayed in edit mode at the same time in full-screen mode, in general, somehow I managed to install it, closed the application-opened it and it seems that the alpha was saved
