Crop
alar73
Crop
Post by alar73 »
Good time of day!
I have this problem
We are in the Viewer mode
Nothing was highlighted
Press Shift + X (Crop, cmd_crop )
I would really like nothing to happen at this time, since nothing is selected, and the click is random
Вut it runs instead ( cmd_Icrop ) with the settings dialog at the top of the screen
This is very disturbing
Is there any way to disable this so that something that isn't needed isn't called
Re: Crop
you means that Crop bar is opened?
alar73
Re: Crop
Post by alar73 »
yes, the panel opens when it is not needed )
Re: Crop
alar73 wrote: Thu Mar 11, 2021 1:12 pm yes, the panel opens when it is not needed )
It's the default behavior
