Good evening everyone.
I was hoping to use Xnview to view my raw\dng files without opening them with Lightroom\Photoshop.
But when I try to open one of them, the colors look terrible...
If I set the preview to embedded Camera Raw, the colors are ok, but the preview is reeeeally small.
Instead when I try half size or full size, the colors looks purplish. I've set the correct ICC profile in settings, but nothing changed...
Image attached
https://1drv.ms/u/s!AslDcWgUCXj9gb4aADv ... Q?e=kovf3y
Raw colors shifted. Maybe a recurrent question, but no answer found
EnricoSlade1
Re: Raw colors shifted. Maybe a recurrent question, but no answer found
there is only the jpeg?
