version 0.98.2 search similar images
judashtibo
Post by judashtibo »
in the version 0.98.2, when I search for similar images and try to sort the result by name or size, it does not work. With the previoues version works perfect. idon't know if it's my problem or the update.
Thank you!
Re: version 0.98.2 search similar images
In previous version it was a bug, the sort is not applied to first item of each row
