0.98.2 deleting files on extrernal drives does not work
TomAugsburg
Post by TomAugsburg »
On Mac Os Mojave deleting pictures on external drives is not possible. The files disappear in XnViewMP but actually they remain on the external drive. When you restart MP the files are there again.
File or folder renaming works fine.
Re: 0.98.2 deleting files on extrernal drives does not work
Ok, i'll check
guille
Post by guille »
any updates on this issue?
I can't reproduce, when i delete files from a external drive it works for me
guille
Post by guille »
I stand corrected.
Deleting files from the right panel (detail list) works fine.
What I have problems is trying to delete folders.
guille wrote: Sun Apr 25, 2021 11:54 pm What I have problems is trying to delete folders.
you have problem with deleting folders on external drive?
guille
Post by guille »
Yes, and I checked permissions & ownership and it looks ok.
I can delete the folders in the internal drive.
All my drives have fileVault.
I gave xnview full access to all drives.
you delete folders in thumbnail view?
