[98.2] Category Sets re-assignment via History not possible.
jadO
Post by jadO »
There seems to be a bug when removing and re-assigning a category via the "History" section.
1. Go to Category Sets
2. Select a file
3. Assign a category by clicking a tag button
4. Assigned category should appear under "Assigned" section
5. Select another file and re-select first file
6. Now assigned categories should appear bold under "Assigned"
7. Remove assignment by clicking the tag buttons under "Assigned"
8. From "History" try to add the removed tag button again by clicking the (still bold) previous category.
Result is the categories cannot get reassigned this way. It seems that the "History" section still believes they are already assigned thus showing them as bold and does not permit a reassignment through it. This is bad as accidently removed categories cannot get reassigned this way and are prone to get permanently removed by accident.
Re: [98.2] Category Sets re-assignment via History not possible.
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
