b1: Thumbnails for folders - long creating
Dreamer
Thumbnails for folders are created as last, when there are any pictures in dir., thumbnails for folders are created after 30 sec. sometimes. I think they should be created first, then th. for images should be created.
XnView 1.82 <x>
XnView 1.82 <x>
ckit
Re: B1: Thumbnails for folders - long creating
I disagree, and thumbnails are not created after 30 seconds, but when all images thumbnail are created...Dreamer wrote:Thumbnails for folders are created as last, when there are any pictures in dir., thumbnails for folders are created after 30 sec. sometimes. I think they should be created first, then th. for images should be created.
Dreamer
It was just example (30 sec.), sometimes also 5 seconds are too long. Folders are on top, so I think thumbnails for folders should be created first. When I browse through many directories, I need to know if I'll go to sub-dir. first, then I need to see thumbnails for images. What other people think?xnview wrote:I disagree, and thumbnails are not created after 30 seconds, but when all images thumbnail are created...Dreamer wrote:Thumbnails for folders are created as last, when there are any pictures in dir., thumbnails for folders are created after 30 sec. sometimes. I think they should be created first, then th. for images should be created.
Hard to decide. I think the stuff that is visible should be created first. Probably this will be a mixture of folders and thumbnails.Dreamer wrote:It was just example (30 sec.), sometimes also 5 seconds are too long. Folders are on top, so I think thumbnails for folders should be created first. When I browse through many directories, I need to know if I'll go to sub-dir. first, then I need to see thumbnails for images. What other people think?xnview wrote:I disagree, and thumbnails are not created after 30 seconds, but when all images thumbnail are created...Dreamer wrote:Thumbnails for folders are created as last, when there are any pictures in dir., thumbnails for folders are created after 30 sec. sometimes. I think they should be created first, then th. for images should be created.
If i start folder thumbnail creation in the same time that thumbnail, so thumbnail creation will be slower!helmut wrote:Hard to decide. I think the stuff that is visible should be created first. Probably this will be a mixture of folders and thumbnails.Dreamer wrote:It was just example (30 sec.), sometimes also 5 seconds are too long. Folders are on top, so I think thumbnails for folders should be created first. When I browse through many directories, I need to know if I'll go to sub-dir. first, then I need to see thumbnails for images. What other people think?xnview wrote: I disagree, and thumbnails are not created after 30 seconds, but when all images thumbnail are created...
Dreamer
Thumbnails for folders should be created first, than thumbnails for images. I'll try to explain why...
- enter the folder with few subfolders and 500 images
- you need to enter subfolder, but you want to check thumbnails first
- thumbnails for (non-visible) images are creating
- you must wait about 16 seconds
- then thumbnails for few subfolders are created
I'm 100% sure it's not good, maybe it's even a bug.
everyone agree with that?Dreamer wrote:Thumbnails for folders should be created first, than thumbnails for images. I'll try to explain why...
No, I don't agree. I think XnView should first determine the items currently shown in the visible part of the file list and then read these items (first folders, then images). When all visible items are read, XnView can continue reading the non-visible items.xnview wrote:everyone agree with that?Dreamer wrote:...
This would give the best result, I think.
Dreamer
Helmut, but I want exactly the same!!!helmut wrote:No, I don't agree. I think XnView should first determine the items currently shown in the visible part of the file list and then read these items (first folders, then images). When all visible items are read, XnView can continue reading the non-visible items.xnview wrote:everyone agree with that?Dreamer wrote:...
Try to enable folders in the browser and my steps above.
Right, we mean pretty much the same. But not 100%: I mean that XnView should track which items are visible to the user and ensure that these are built up - when opening a folder but also when scrolling while the thumbnails are about being created. That's a slight but important difference.Dreamer wrote:...
I guess my suggested approach is hard to implement, so we should implement the solution that you have suggested (creation of thumbnails for folders first, then thumbnail for images).
Dreamer
OK, I must wait about 16 seconds for creating thumbnails for (non-visible) images (500), till I get thumbnails for few (visible) folders.helmut wrote:Another aspect came to my mind: For creating a thumbnail for an image, you have to read one file. For creating a thumbnail for a folder, you have to read four files.
This aspect would argue for creating thumbnails for images, first.
Think this needs more thinking and more discussing...
And - I must wait 1 second for creating thumbnails for about 20 folders (just tested)!
So, what do you think now?
Xyzzy
In my opinion 'Render first what you see is best', regardless of what is shown (folders or files).
Because if I display some items in file list, I expect them to be presented (thumbnailed) first- they are the most important for me now. For files it now works OK: if I browse very big directory and use slider to move to the end, thumbnails for displayed files are created immediately, not at the end. Now it should work the same way for folders.
X.
X.
Dreamer
