"Close all" warning
sasko1
"Close all" warning
Post by sasko1 »
Hi!
Quick question:
When I had XnView open and some images, and when I hit X on top right, so I would close XnView, I always had warning pop up, something like "do you really wanna close all".
I accidentally checked "never warn me again", and now I can't find, where I can enable this feature again.
Can someone point me to right direction?
Thanks.
Re: "Close all" warning
sasko1 wrote: Sun Mar 14, 2021 12:15 pm When I had XnView open and some images, and when I hit X on top right, so I would close XnView, I always had warning pop up, something like "do you really wanna close all".
On Tools > Settings > General -- General tab there is an option Reset all confirm prompts which would be the nuclear option...
I'm not immediately sure if there is a more specific option, but you could easily check through the other Settings options if you wish.
sasko1
Post by sasko1 »
Thx, will try this one. I just hope, it won't cause any problems elsewhere.
sasko1 wrote: Sun Mar 14, 2021 1:31 pm Thx, will try this one. I just hope, it won't cause any problems elsewhere.
I think at the worst you would have to reset some other options, but that should be easy as they appear.
If it were likely to be more of an issue, you could backup your .ini file first, so that you could restore your existing settings if needed.
