I've just moved from Classic to MP and I have adjusted to it well.
One thing I'm puzzled by:
The properties button in the view and browse modes produces different results (see photos).
I'd prefer if both displayed the same version: the view one.
Please advise.
Properties
Gummo
Properties
mudo_j
Re: Properties
I can see no need for changes here.
Re: Properties
Gummo
Re: Properties
This problem is supposed to be fixed in XnView MP 0.98.3. Please check and confirm the bug fix here.
Gummo
Re: Properties
Thanks Pierre.
I've just installed the new version but the problem still exists.
Re: Properties
you need to change your xnview.ini
[Properties]
osDialog=true-
Gummo
Re: Properties
I've amended the .ini file. Now, both browse and view display the Windows properties dialog (see Browse.jpg in the original post), not the Xnview one.
Re: Properties
you would like the XnView properties dialog everywhere?Gummo wrote: Thu May 06, 2021 5:56 pm I've amended the .ini file. Now, both browse and view display the Windows properties dialog (see Browse.jpg in the original post), not the Xnview one.
Gummo
Re: Properties
It's not a major issue, or even a medium issue as the important info is available on both browse and view. I reported it initially as I thought it would help uniformity if both produced the same report.
