Copy / move images / files to the favorite folders?
Elk
How could on copy / move images / files to the favorite folders (panel, which is not possible) being always visible here without having to open them each time? I do not want to each time click me to the (favorite folders) to copy or move images.
Rick
Re: Copy / move images / files to the favorite folders?
You can't copy to the favorites folders but you can click on the tab above that says folders then find the folder to copy or move to.
Easier way is to ALT C for copy or ALT M for move then find the folder there. Then you will have a list of last used folders for next time
I also created a basket with some various folder that I don't use so often with shortcuts and hard links
Rick
Rick
Elk
I cannot find such a tab here. I have a panel /area called "Folders" with a folder tree, but I do not want to each time click through the folders.but you can click on the tab above that says folders then find the folder to copy or move to.
Where is that list?Then you will have a list of last used folders for next time
Sorry, what basket? Whatfor?I also created a basket with some various folder that I don't use so often with shortcuts and hard links
Rick
Well opening the folder tree is one option.Elk wrote: Sat Mar 20, 2021 8:13 pmI cannot find such a tab here. I have a panel /area called "Folders" with a folder tree, but I do not want to each time click through the folders.but you can click on the tab above that says folders then find the folder to copy or move to.
Try selecting a photo and then pressing ALT C
You will get a dialog like this
Rick
Rick
Elk
Ah yes, the shortcut was not working before, was occupied by another program, thank you. Working now. So that is the fastes / easiest way to copy and move within XnView.
Thank you.
Thank you.
Rick
There is always cut and pasteElk wrote: Sun Mar 21, 2021 7:43 am Ah yes, the shortcut was not working before, was occupied by another program, thank you. Working now. So that is the fastes / easiest way to copy and move within XnView.
The "basket I mentioned is a folder called "_basket" that contains symlinks and shortcuts to folders I use, but use less often
Rick
Rick
Elk
Yes, but you have to click one to the folders.There is always cut and paste![]()
The basket, yes, so two clicks away from the (most used) folders.
Many thanks!
