b1: No transformations work while on new tab.
Locked
marsh
Post by marsh »
When using batch convert, no transformations work when pressing "go" while looking at transformations tab.
Re: b1: No transformations work while on new tab.
marsh wrote:When using batch convert, no transformations work when pressing "go" while looking at transformations tab.
I can't reproduce it
marsh
Post by marsh »
After transformations are chosen, one needs to change back to the main tab for them to work. They don't work if the process is started while the transformations tab is in foreground. I used resize> 80% as a test.
I can confirm. The conversion is performed, but the converted images have still original size. :bug:
Looks as if the transformation and/or parameters do not become active until you switch tab page.
Now i confirm
Xyzzy
Post by Xyzzy »
Fixed in b2 but there's another problem:
Used Resize Canvas to test. Chosen background color is black, but added canvas is grey, not black.
X.
Xyzzy wrote:Fixed in b2 but there's another problem:
On which picture do you have tried? Be carefull if it's a colormap picture...
Xyzzy
Post by Xyzzy »
On a GIF file with 88 colors. Actually, I cannot get any other background than grey
X.
Xyzzy wrote:On a GIF file with 88 colors. Actually, I cannot get any other background than grey
It's normal, you must convert it in RGB before
Dreamer
Post by Dreamer »
OK, so move to "Solved.."?
Locked
