b1: aborted file delete causes crash (view-/fullscreenmode)
Locked
FlorianH
Post by FlorianH »
If i am in viewer or fullscreen mode and delete the current picture by pressing delete or shift+delete there is a popup/request if i'm realy sure.
If i answer this dialog with cancel (esc) xnview crashes.
(config: xp pro sp2)
Re: b1: aborted file delete causes crash (view-/fullscreenmo
FlorianH wrote:If i am in viewer or fullscreen mode and delete the current picture by pressing delete or shift+delete there is a popup/request if i'm realy sure.
confirmed
Xyzzy
Post by Xyzzy »
Fixed in b2.
X.
Xyzzy wrote:Fixed in b2.
X.
Have you reproduced the problem in Beta 1, Xyzzy? I'd like to have a confirmation of the original tester, if possible.
:arrow: Back to group "Fixed in B2"
Dreamer
Post by Dreamer »
X.
I can confirm bug in B1, no bug in B2 = fixed, confirmed.
So confirmed by Pierre, Xyzzy and me, moving to Closed, but with shadow.
Dreamer
Locked
