duplicate images in category view
BogongBreeze
Post by BogongBreeze »
When I open some categories there are duplicate thumbnails. When I go to the folder, there is only one file listed for each one that's duplicated in the category view, so I know the actual files are okay and figure the thumbnails have been messed up somehow.
What is the best way to fix this?
Re: duplicate images in category view
Do you use 'base path'?
BogongBreeze
Thank you for the quick response. I have to admit I don't know if I used 'base path" or not because I'm not sure what that is. Sorry.
I've decided to rebuild the catalogue and thumbnails (backed them up first) - using the process described here - or as close as I can get with the current version of XnViewMP. I think that should fix this problem, and maybe a few others as well :D
EDIT: This is how I'm rebuilding the database and thumbnails: https://forum.xnview.com/viewtopic.php?t=36082
