Sorting files by extensions and the order of names
dev/null
Post by dev/null »
I'm not sure if this is a bug or if it should be a feature request, but I'm trying to report it here.
I have doubts about sorting files (sort by extension).
I marked in red which files are concerned
Total Commander (in my opinion this is the correct order 👍)
XnViewMP (a little non logical ordering):
Re: Sorting files by extensions and the order of names
The second order used is same as 'Name', so numeric is used
dev/null
Post by dev/null »
I would suggest that it would be better to change it to order as it does in Total Commander. Just my opinion
