How to view SVG files in XnView browser?
mibro
Post by mibro »
Is there a way how to view svg files in XnView MP browser?
Thank you for any tips.
Re: How to view SVG files in XnView browser?
yes, remove svg from 'Exclude' list in settings>File list>custom filter
xnview wrote: Tue Mar 30, 2021 7:55 am yes, remove svg from 'Exclude' list in settings>File list>custom filter
Then svg files will be displayed in the browser as an icon, currently no way to display a thumbnail?
mibro
Post by mibro »
I can open svg with XnView, but it would be also great if I could see svg thumbnails in the browser.
mibro
Post by mibro »
It works! Thank you!
mibro wrote: Tue Mar 30, 2021 2:23 pm
You can see thumbnails, or just the file icon?
I ask as in a similar thread last week it seemed that currently thumbnails weren't available.
VictorVG
Post by VictorVG »
SVG removed:
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
@VictorVG
Sorry, to be clear is logotype-mail.svg above displayed as a thumbnail or an icon?
VictorVG
Post by VictorVG »
This is a SVG logo file with the pages saved in the HTML browser. Get such files easily - a browser "Save page as HTML entirely" and in the ./<save_page_name>_Files subdirectory We look at the presence of *.svg . :D
HaroldFinch
Post by HaroldFinch »
xnview: first, before saying anything else, I want to thank you for this program.
Concerning your reply above, yes, that Exclude solution works for me as well.
But...
1) why do I have to do that? If XnView supports SVG files, why is svg in the exclude list in the first place? Is the SVG support only preliminary, maybe unstable or something?
2) in fact, there ARE issues:
a) when XnView opens SVG files that I have created, it does so at a super small size, much smaller than other programs do. For example, there is one file that I am looking at which ~10 cm wide in XnView, ~22.5 cm wide in Brave & Chrome, ~23 cm wide in GIMP (IF, when opening the file, I manually override the default 90 DPI and replace it with my monitor's actual DPI of 163), ~42 cm in LibreOffice Draw.
b) if in XnView I zoom in on an SVG file, yes, the image blows up, but it looks awful. It is as if XnView converts the SVG into a bitmap and then simply blows up the bitmap. That is no good! The whole point of SVG's vector graphics is that they should support perfect scaling!
SVG support is very basic, and not in vector
HaroldFinch
xnview wrote: Thu Sep 16, 2021 12:59 pm SVG support is very basic, and not in vector
xnview: thanks for confirming.
I assume that you are using some 3rd party code library for the current SVG support. Do you know if that library has plans to properly supprt SVG vector graphics in the future? Or is there another code library which does?
Currently i use the one from QT libs, and i'm not sure that support will be better in future...
