Description file will miss after move some file to another folder.
RobinHu
Post by RobinHu »
Subject: 0.98.2: <Description file will miss after move some file to another folder.>
XnView: MP 0.98.2 - 64 bit
OS: Mac / 11.2.3(20D91)Big Sur/64bit
I had make a,b,c files note in descript.ion file,
and, move (drag) c file to another folder.
after that , thw descript.ion file will disapper.(in both folder)
Effect: descript.ion file was miss.
1. Note description on 3 file, ex, a ,b & c
2. Drag c file to another folder.
3. clink on other folder, and click back to the folder
4. descript.ion file was missed.
Re: Description file will miss after move some file to another folder.
I can not reproduce, do you drag&drop from thumbnail view into folder tree?
RobinHu
Post by RobinHu »
I drag files from list view into folder tree.
are you able to reproduce each time? I can't reproduce
RobinHu
Post by RobinHu »
I switch to use 0.95 few days.
I use 0.98.2 again,I cannot reproduce again.
It become normal.
Thank U for Ur support.
