How do I Make the Shortcut Thumbnails Look Better?
KingKay
Post by KingKay »
When i change to thumbnail view, the folders with Costumized thumbnails look fine, but the ones with a shortcut customized thumbnail look bad.
Is there a way to fix this or is it a Windows problem.
I Have: Windows 10 Pro/64-Bit
Re: How do I Make the Shortcut Thumbnails Look Better?
how do you customize thumbnails?
