Undo for deleted files
Pcdoedel
Post by Pcdoedel »
In XnView you could Undo deleted Files with CTRL+Z. This seems not present in MP. I searchted and found some discussions, but I am not sure if it was now in the meanwhile implemented, or if it is at least planned to be implemented.
A file deleted with MP can be re-done with CTRL+Z in the Explorer (even if the Explorer was not open at that time). It would be better if the CTRL+Z function would be available also in the MP version.
Rick
Re: Undo for deleted files
Post by Rick »
+1 for that one
Rick
Pcdoedel
Post by Pcdoedel »
is there in the meanwhile any solution - at least I did not find?
