0.98: no more possible to expand/collapse directories in favorites pane
kochphil
Post by kochphil »
XnView: MP 0.98 - 64 bit
OS: Linux - 64bit
Since version 0.98, it's no more possible to expand/collapse directories in favorites pane, small white triangles are missing on the left side of each directory icon in favorites pane (it was ok till version 0.97.1)
Effect: not possible to expand/collapse directories in favorites pane
1. Activate favorites pane
2. See that there is no small white triangles on the left side of directory icons
Actual behaviour (bug): Small white triangles are missing on the left side of directory icons :bug:
Expected behaviour: There are small white triangles on the left side of directory icons allowing expand/collapse of those directories
Re: 0.98: no more possible to expand/collapse directories in favorites pane
Please change
favShowFiles=true
in your xnview.ini
kochphil
Post by kochphil »
It's ok with that setting.
Thank you for that information.
