When I first open XnView on AIX (with the 3 menu options) the program picks up the color scheme that is in use. When I open a picture either thru the menu OR from command line the menubar and print/capture dialogs are black text on black background always. Is this a problem anyone else has or is it just me?
Can anyone give me a tip? I have a couple of screen captures if it would help. Thanks a bunch.
http://users.adelphia.net/~luenyar/firstopened.png
http://users.adelphia.net/~luenyar/afteropenpic.png
Milton
AIX 4.3 and XnView
Luenyar
AIX 4.3 and XnView
I get up every morning determined to both change the world and have one hell of a good time.
Sometimes this makes planning my day difficult. -- E.B. White
Re: AIX 4.3 and XnView
Could you send me the result of the command xdpyinfo, please?Luenyar wrote:When I first open XnView on AIX (with the 3 menu options) the program picks up the color scheme that is in use. When I open a picture either thru the menu OR from command line the menubar and print/capture dialogs are black text on black background always. Is this a problem anyone else has or is it just me?
Milton
