Image selection: Use a hotkey to select image instead of having to check that little box in the top left?
vovin
The tiny little box at the top left of each image isn't so great when going through thousands of images. I want to be able to check that box using a hotkey instead. Is this possible?
Re: Image selection: Use a hotkey to select image instead of having to check that little box in the top left?
This square box is used to tag files
hotkey is (Ctrl T)
You can select many photos and type Ctrl T to tag them all
See also right-click, "tag" menu
(Tagging files is a spécific feature in XnViewMP used to mark up files ; It's not "tagging" as used elswhere which means "adding keywords")
hotkey is (Ctrl T)
Catalogage avec XnviewMP :
