Specifically, if I opened a tab in view mode, I was wondering if I could enable a sidebar that shows the thumbnails of the other images in that I have open in that tab, like you can in fullscreen mode. (I select specific groups of images and open them in view tabs instead of whole folders.)
I want to say that I previously used it in Xnview MP before and that the thumbnails appeared on the right side of the window, but I can't remember the configuration or keyboard shortcut that made it possible.
Is there a way to view thumbnails while in view mode?
kuchiki977
Re: Is there a way to view thumbnails while in view mode?
Move the mouse to the top
kuchiki977
Yes, that works in fullscreen mode, but I was wondering if there was something similar in the tabbed viewer mode?
Currently only when you are in fullscreenkuchiki977 wrote: Tue May 04, 2021 6:12 pmYes, that works in fullscreen mode, but I was wondering if there was something similar in the tabbed viewer mode?
