Not sure if this is the place for this type of report but exiftool, which is used by XNViewMP (at least on MacOS) has a serious security vulnerability. It allows for arbitrary code execution if it tries processing certain malicuously crafted images (regardless of extension):
https://twitter.com/wcbowling/status/13 ... 7321415687
https://cve.mitre.org/cgi-bin/cvename.c ... 2021-22204
Patched version of exiftool is 12.24:
https://github.com/exiftool/exiftool/co ... 6bdadb3800
Hoping you can update to versionused in XNViewMP and get a new release out with the patched version of exiftool.
Thanks!
exiftool needs to updated to latest version (security vulnerability)
lasdgu
Re: exiftool needs to updated to latest version (security vulnerability)
a new version of XnView MP will be soon available
lasdgu
thanks as always, pierre!
