When adding text to image, the text font size seems to be in fixed pixel.
It does not adjust to the real/actual image resolution.
Is this the case of current xnview?
Or are there any settings to set inorder to add the correct font size?
Adding Text to Image - Is the text font size set in fixed pixel?
f-spider-man
Re: Adding Text to Image - Is the text font size set in fixed pixel?
you would like to use point size?
