MP 0.98.3: Mixed file/folder sorting does not work
Irrawaddy
Post by Irrawaddy »
XnView MP Windows, Version 0.98.3 64bits (May 6 2021)
Mixed file/folder sorting does not work: folders are always sorted first, then files, even when this option is checked in Settings > File list.
Franky
Re: MP 0.98.3: Mixed file/folder sorting does not work
Post by Franky »
It's ok for me, have you validate in the settings, in the File List tab ?
which sort do you use?
Irrawaddy
Post by Irrawaddy »
My sort is: Date > Descending.
This problem is supposed to be fixed in XnView MP 0.98.4. Please check and confirm the bug fix here.
Irrawaddy
Post by Irrawaddy »
I can confirm the bug is fixed in 0.98.4.
