BBedit removing Dark Theme
blackxacto
Post by blackxacto »
In a previous version of XnViewMP in order to change the gray background for the thumbnail view, I deleted the Dark Theme and replaced MyThumbListView at rgb 0,0,0.
I can no longer find Dark Theme using BBedit. Does anyone know what it takes to change the gray background to black?
Learning to mind my own business. 8)
blackxacto
Re: BBedit removing Dark Theme
I don't know what has happened, but there is no gray color in the background. I changed a few RGB numbers in the BBedit window on the invisible xnview.ini file, maybe I changed the gray to black. But there is no gray anymore. So in conclusion, I used terminal to show invisible files. Found the xnview.ini file, opened the file in Bbedit, and looked for RGB numbers that related to "Back" or "Background" then changed to RGB: 256, 256, 256. Saved the changes, then re-hid invisible files in terminal.
Maybe it worked. Looks like it.
