0.85: Creating a directory in the right pane does not update the left directories pane
Maddo
Post by Maddo »
XnView: MP 0.85 - 64 bit
OS: Windows 64bit
Effect: Mismatch between reality and what is shown on screen
1. Go to any directory
2. Create a new directory in the right pane by right clicking and selecting new folder
3. Look at the left pane: the directory is not present
Actual behaviour (bug): The directory pane is not updated, the new folder does not appear, the same happens if an existing folder is renamed
Expected behaviour: The directory pane should update when any change in the right pane happens
______________________________________________________
Re: 0.85: Creating a directory in the right pane does not update the left directories pane
please update to lastest version
Maddo
Post by Maddo »
First turns out I was on 0.98.2 but while copypasting the template I assumed it was the latest version,
anyway thank you, the newer version 0.98.3 fixes the issue so this bug report can be considered closed
