How to install 8BF plugin, e.g. SmartCurve?
rsbrux
Post by rsbrux »
I have an 8BF plugin, SmartCurve, which I would like to use in XnView MP. I have found numerous posts about using plugins, but none which explain how to install one in XnView MP. IIRC, it is a 32-bit plugin. Am I therefore limited to 32-bit XnView MP?
I have two versions of SmartCurve, both of which claim to be V2.2, but a binary file comparison shows differences, which makes me nervous about using them. The newest source that I find for the plugin is softpedia. Is that version safe to use with XnView? Is there a more recent (or 64-bit) version, or is there another plugin which can achieve the same effect?
XnViewMP 1.9.5 64-bit
running under Windows 11 Pro x64 25H2
Re: How to install 8BF plugin, e.g. SmartCurve?
rsbrux wrote: Mon May 24, 2021 4:21 pm I have an 8BF plugin, SmartCurve, which I would like to use in XnView MP. I have found numerous posts about using plugins, but none which explain how to install one in XnView MP. IIRC, it is a 32-bit plugin. Am I therefore limited to 32-bit XnView MP?
I installed SmartCurve once to have a quick look, I'm not sure whether it was in XnView MP or Classic. I can't give detailed advice on installing 8BF plugins as I have only installed one once or twice, and I remember for me it involved some trial and error.
In general 32-bit plugins can only be used with 32-bit applications. so you would likely be limited to using XnView MP 32-bit.
However possible good news: If you need a curves function, native support was added to XnView MP some time back at Image > Adjust > Curves...
and so it should be available in both 32-bit and 64-bit versions. :D
I'm afraid I don't have any information on that, but hopefully you now have a good solution?
