Please make the scrollbar in the dark theme more "noticeable". You can, for example, make the background brighter or the slider itself. When there are many files in a folder, it is almost impossible to see it.
Fix for Dark Fusion theme
MARK2580
seabirdr
Re: Fix for Dark Fusion theme
I think this is designed to look like this.If it were brighter it might be too eye-catching. The color is very subtle and the slightest misstep could destroy the harmony.
MARK2580
Unfortunately, it is practically invisible. I have to turn the mouse wheel and look for at least some movement in order to understand where he is.seabirdr wrote: Fri May 28, 2021 3:16 pm I think this is designed to look like this.If it were brighter it might be too eye-catching. The color is very subtle and the slightest misstep could destroy the harmony.
- Forum Librarian
As a workaround, you could add the following lines to View → Theme → Dark theme → style_sheet_win.qss:MARK2580 wrote: Thu May 27, 2021 2:32 amPlease make the scrollbar in the dark theme more "noticeable".
QScrollBar::handle {
background-color: rgb(128, 128, 128);
QScrollBar::handle:hover {
background-color: rgb(153, 153, 153);
QScrollBar::handle:pressed {
background-color: rgb(204, 204, 204);
MARK2580
This is a bad workaround. "dark theme" is terrible, I like Fusion better.XnTriq wrote: Sat May 29, 2021 7:00 pmAs a workaround, you could add the following lines to View → Theme → Dark theme → style_sheet_win.qss:MARK2580 wrote: Thu May 27, 2021 2:32 amPlease make the scrollbar in the dark theme more "noticeable".
QScrollBar::handle { background-color: rgb(128, 128, 128); } QScrollBar::handle:hover { background-color: rgb(153, 153, 153); } QScrollBar::handle:pressed { background-color: rgb(204, 204, 204); }
- Forum Librarian
Changes to style_sheet_win.qss are applied to all themes including Fusion dark (restart required).MARK2580 wrote: Sun May 30, 2021 1:45 amThis is a bad workaround. "dark theme" is terrible, I like Fusion better.
Here's an even brighter version:
border-color: rgb(102, 102, 102);
background-color: rgb(170, 170, 170);
border-color: rgb(119, 119, 119);
background-color: rgb(187, 187, 187);
border-color: rgb(136, 136, 136);
}Code: Select all
background-color: #999;
border-color: #666;
background-color: #aaa;
border-color: #777;
background-color: #bbb;
border-color: #888;
MARK2580
For me, changes only occur in the "dark" theme, when I select Fusion everything returns as it was. Yes, I restarted the program more than once.
- Forum Librarian
please check this topic
