b1: Can't store cache on removable drive.
marsh
Post by marsh »
Xnview will not store cache on removable USB or virtual disk when the main program is on fixed HD. Alternate location for Cache>Directory works on fixed HD only. However, when running Xnview program located on USB, it will store cache in its subdirectory. I don't know if this is by design or a problem.
XnView 1.82 <x>
Re: Can't store cache on removable drive.
marsh wrote:Xnview will not store cache on removable USB or virtual disk when the main program is on fixed HD. Alternate location for Cache>Directory works on fixed HD only. However, when running Xnview program located on USB, it will store cache in its subdirectory. I don't know if this is by design or a problem.
Currently by design
