0.98.4: Parent category not applied on Enter
solowing
Post by solowing »
Subject: 0.85: <short bug title>
XnView: MP 0.98.4 - 64 bit
OS: Windows 10
In Settings>Metadata>IPTC & XMP, there's a setting called "Automatically apply parent keywords." When this setting is applied, if you click a subcategory (btw, I think the mixed usage of 'keyword' and 'category' in this program is a bit confusing), the parent category is applied. However, you can also apply a category by selecting an image, then searching for the category in the Categories Pane. When the result shows up in the dropdown box you can hit Enter on it to apply the category. In this case, however, parent categories are not automatically applied even if you have them set to. This means that the preference settings only works if you apply categories with the mouse.
Effect: Categories are more time-consuming to apply.
1. Go to Settings>Metadata>IPTC & XMP
2. Enable "Automatically apply parent keywords."
3. Select an image.
4. Open the Categories Pane and use the quick-search to find a subcategory.
5. Hit Enter on the subcategory.
6. The subcategory is applied, but the parent category is not.
Expected behaviour: The parent category should also be applied.
Re: 0.98.4: Parent category not applied on Enter
solowing
Post by solowing »
Thank you!
This problem is supposed to be fixed in XnView MP 0.99.0. Please check and confirm the bug fix here.
Gwenael Q.
Post by Gwenael Q. »
Issue fixed. Parent categories applied on Enter.
Tested with version 0.99.1 x64 on win 8.1 x64
