0.98.4: PCX files displayed with wrong aspect ratio [Solved]
GeckoN
Post by GeckoN »
XnView: MP 0.98.4 - 32bit
OS: Windows 10 64bit
Loading a PCX file generated by SpeedSys (PC benchmark for DOS) results in the image being stretched vertically in both the viewer and the browser.
Effect: Image displayed with an incorrect aspect ratio.
1. Extract the attached ZIP file (SSTIMG01.zip)
2. Open the contained PCX file (SSTIMG01.PCX) in the viewer (or browser)
Actual behaviour (bug): Image displayed with an incorrect aspect ratio (see xnviw.png) :bug:
Expected behaviour: Image displayed with the original 4:3 (1.33) aspect ratio (see irfanview.png).
Note: I have the "Pixel ratio" option set to "Square" (default), which should maintain the original aspect ratio if I understand things correctly. The status bar area shows the correct information: "640x480x4 (1.33)". Pictures in other formats are displayed with their original (correct) aspect ratios.
Re: 0.98.4: PCX files displayed with wrong aspect ratio
you need to disable settings>Adjust zoom if ...
GeckoN
Post by GeckoN »
xnview wrote: Mon Jun 14, 2021 12:44 pm you need to disable settings>Adjust zoom if ...
That fixed the "problem". Thank you.
