Problem with crop
Mrakobes666
Problem with crop
Post by Mrakobes666 »
When you use the crop-save-go to next button, the cropped image is rotated 90 degrees
Re: Problem with crop
could you post the image used?
Mrakobes666
xnview wrote: Tue Jun 22, 2021 7:59 am could you post the image used?
I'm sorry I didn't answer - I was on a business trip. Files that behaved like this I can't lay out-documents. Experiments with photographing the wall did not give this result. I can assure you that I did not like several rotateit files, possibly due to EXIF
